Enabling/disabling audio control(s)
  • freadZdeadZ
    by freadZdeadZ » Sat Feb 17, 2024 4:39 pm
    Hi there,
    I am doing a Light installation that will sometimes react to music/beats, and sometimes not; apart from (re-)creating and deleting audio controls that have been set up, is there a way (via another control, or via a scene/cue recall) to enable/disable an audio control?
    Thanks in advance for the help!
    freadZdead
    Re: Enabling/disabling audio control(s)
    by mad-matt » Mon Feb 19, 2024 12:43 pm
    You can use the "Controls Combiner" module, you can assign your audio analysis channel to one of its input and use a Cue to change the Controls Combiner "mode" to switch from this input to another (like a multiplexer / switch)
