FPS dropping
  • MikkelM
    FPS dropping
    by MikkelM » Sat Mar 02, 2024 8:02 pm
    Hi there.
    I have a Madmapper 5.5.5 where FPS halves when the Madmapper-window isnt selected.
    Engine is OpenGL
    FPS is set manually to 50
    Double buffer is on
    Increase priority is on
    There are plenty of headroom in both CPU and GPU power.
    I am running windows 11
    Re: FPS dropping
    by mad-matt » Tue Mar 05, 2024 5:29 pm
    FPS is dropping when doing what ?
    Dropping at which value ?
    Do you play movies ? Shaders ?
    What's your graphics card ? Drivers up to date ? On Windows if you have an integrated GPU (like an intel HD inside the CPU) and a discrete GPU (ie nVidia / AMD), you have to set the "Main Display" to a display connected to your discrete GPU.
