Input card for Madmapper NDI
  • simonhu
    by simonhu » Tue Mar 05, 2024 4:32 pm
    i need an input for a NDI stream of 6'500x1'200 Px.
    Does anybody know a input card that is capable for this kind of resolution?
    Thank you and have a good day.
    All best
    Re: Input card for Madmapper NDI
    by mad-matt » Tue Mar 05, 2024 5:21 pm
    What do you mean by "input card" ?
    Do you want MadMapper to send or receive an NDI stream ?
    NDI is a network protocol so you generally just plug your computer to your local network to receive or send an NDI stream.
  • simonhu
    by simonhu » Tue Mar 05, 2024 5:57 pm
    sorry for the bad description.
    We would like to install an HDMI / DP / XX input card in the pc where we want to connect an external source like a pc or player.
    We then want to integrate this input into the Madmapper via NDI
    by mad-matt » Sun Mar 10, 2024 1:25 pm
    You can use any input device that is supported by default video acquisition drivers on your platform. On macOS any device that appears in QuickTime (support of Apple AVFoundation framework needed), on Windows it must support Windows MediaFoundation or DirectShow/DirectX (you can choose in MadMapper preferences which API to use for video capture)
    There are many cheap HDMI-USB devices on the market.
    MadMapper also has native BlackMagic driver integration, so you can use something like UltraStudio Recorder 3G
    by franz » Wed Mar 13, 2024 11:48 am
    NDI spark 4k does HDMI-> NDI HX, great quality, recommended.
