MadMapper loses file paths
  • martenbiehl
    by martenbiehl » Wed Mar 06, 2024 4:03 pm
    Hi everyone,
    I run into this problem where every time I open a MadMapper file it loses all file path information on another computer. So that I need to remap one video file per folder... The relative path doesn't change, it's only the absolute path and I am moving from Mac to Windows.
    Do you have any tips on how to handle this?
    Best,
    Marten
    Re: MadMapper loses file paths
    by mad-matt » Sun Mar 10, 2024 1:19 pm
    Relative pathes should be handled properly. I remember we recently solved an issue when switch from macOS to Windows or something like that. Which version of MadMapper are you using ?
  • martenbiehl
    by martenbiehl » Tue Mar 19, 2024 11:23 am
    Hi Matt,
    I figured it out now: the client was opening the file with an older version of madmapper that was still on the computer. So I guess the changes in filepath handling where the source but should be no issue in the future.
    Best,
    Marten
