Different versions of MiniMad?
  • AgentD
    by AgentD » Fri Mar 15, 2024 7:45 pm
    I own several MiniMad that I bought over the years and one of them is blue. My questions are
    - Is there any difference between these in terms of versions and capacity? For example can I hook up black ones and blue one to the same hub and run them without going out of sync?
    - (Blue being the oldest one) Can I use blue one for interactive installation such as using it with Arduino and Touch board?
    - How can you tell which version they are (if any)
    Thank you!
    Re: Different versions of MiniMad?
    by franz » Thu Apr 25, 2024 5:59 pm
    they are the same, we just changed the color of the case as some users complained blue was too visible ...
