Possible Issue with Edge Blending and Mesh Warping in MadMapper 5.5.5
  • Lumenarius
    by Lumenarius » Sun Mar 17, 2024 9:20 pm
    I was recently doing some blending between multiple screens in a warehouse situation.
    The feature of the warehouse were wonky and so the different screens needed mesh warping AND edge blending (soft edge).
    I noticed what I think is a bug.
    The issue is if you add mesh warping by right-clicking the quad "Add Warping Point" (great feature by the way!) it will throw off the soft-edge and have it start at the new point you added.
    I don't believe this is the desired or expected effect.
    Can we take a closer looking into this and see if this is indeed and issue and what we need to do to fix it?
    I will note that if you manually "generate grid" there are no problems. Only when you right click.
    See attached screenshots.
    Screenshot 2024-03-17 at 1.18.10 PM.png (59.48 KiB) Viewed 6064 times
    Screenshot 2024-03-17 at 1.15.19 PM.png (248.75 KiB) Viewed 6064 times
  • Lumenarius
    Re: Possible Issue with Edge Blending and Mesh Warping in MadMapper 5.5.5
    by Lumenarius » Sun Mar 17, 2024 9:21 pm
    On the output side you can see the very left quad is normal with soft-edge.
    The middle has soft edge AND mesh warping but with manual "generate grid".
    The right one is an issue as after manually adding a point the start of the soft edge changes.
    This can throw off the blend and it won't go past it.
    We got weird with the work arounds but I do not believe this is the intended behaviour.
    by franz » Wed Mar 20, 2024 11:37 am
    thanks for reporting, we'll investigate the issue
    by mad-matt » Thu Mar 21, 2024 4:54 pm
    We have fixed this issue. We'll release MadMapper 5.5.6 with a bunch of fixes asap. Thanks!
  • Lumenarius
    by Lumenarius » Mon Mar 25, 2024 7:46 pm
    Absolutely legendary!
    Thanks for the quick response and fix Franz and Mad-Matt!
