Surfaces Flicker with other media on CUE loading
  • bernielomax
    by bernielomax » Thu May 30, 2024 7:42 am
    Hi everyone
    I need some help understanding why this is happening to me
    I have one scene with the all my surfaces with media loaded. a simple JPEG. when I load a new cue on top of it with other surfaces that are NOT in the initial scene, they new surfaces flicker with other media.
    Does this happen with anyone? My laptop is at the memory limit. 50% with the project ongioing 55% with the medias I am loading.
    Please assist.
  • ProjectileObjects
    Re: Surfaces Flicker with other media on CUE loading
    by ProjectileObjects » Fri May 31, 2024 6:52 pm
    Could you share your project or be more specific about how you have the Scenes and Cues setup? For example, is there a layer over top of another, or are you toggling on / off a quad layer vs turning down the opacity?
    You can use the inspector in the top right corner of Scenes and Cues to look at the intricacies of what parameters are changing in between Scenes/Cues.
Users browsing this forum: Bing [Bot] and 30 guests
