Editing surfaces without affecting Sensors
  • dnelson7
    by dnelson7 » Fri May 31, 2024 5:46 am
    I have an interactive installation that uses touch sensors to trigger videos surfaces. I've used warping points to make the surfaces into custom shapes. We moved the installation to a new location and now the surfaces don't line up properly. I tried editing the surfaces, but they snap back to their original state. I could use edit mode, but I don't want to mess up the interactivity of the sensors. How do I update the position of the surfaces without breaking the sensor interactivity?
    Thx
    Re: Editing surfaces without affecting Sensors
    by franz » Wed Jun 19, 2024 9:58 am
    EDIT mode -> then just click the parameter you want to update. If the stored value is different than the current value, it should be orange. Clicking will turn it red and update the parameter to the current value.
Users browsing this forum: No registered users and 52 guests
