MM won't run as a standard user
  • risehigher
    by risehigher » Wed Jun 12, 2024 12:41 am
    Hi everyone,
    I work usually with mac, but now I need to work with Windows 10. I ran into a problem where I must start MM as a admin, in order to make it work.
    If I start it as a standard user, none of the materials or generators will load.
    An example for an error is "Included file not found in file Line Patterns.fs: #include "MadNoise.glsl" "
    Can anyone tell me please how I can change permissions in Windows or an other way to fix this? Or do you all run your MM instances as admin?
    Thank you,
    Michael
    Re: MM won't run as a standard user
    by mad-matt » Mon Jun 17, 2024 12:50 pm
    I saw a bunch of reports like this that we solved by disabling OneDrive. It seems one driver can make "offline" (in the cloud) files that MadMapper need that are located in folder %AppData%\Garagecube\MadMapper\MadamScripting_[VERSION]
    For 5.5.6 that's in %AppData%\GarageCube\MadMapper\MadamScripting-24040421052
    Those files are then 0 bytes and MadMapper can't load shader code needed.
    Can you have a look at file size of:
    %AppData%\GarageCube\MadMapper\MadamScripting-24040421052\MM_FX.glsl
    You should ensure that OneDrive doesn't put those file offline. Please let us know
