Red dot on media
  • reddog1
    Red dot on media
    by reddog1 » Mon Jun 17, 2024 10:47 am
    basic question, have just returned to using M8 after some time... What are the orange and red dots on media thumbnails in media sets?
    Thanks.
    pele2010
    Re: Red dot on media
    by pele2010 » Wed Sep 18, 2024 11:32 am
    hi,
    if I am not mistaken this means, that the media is not loaded into ram.
    the way m8 works is that it depends on a fast machine.
    if you have a lot of ram, than the media gets stored there.
    You can also define which media is preloaded.
    If not preloaded then the media will not play as smooth as if fully loaded.
    If you press the in the left corner of the footage window you will find
    a window that tells you everything you need to know about the footage
    and you also can make decisions on how the footage is viewed if you processed the footage.
    the is a manual on your space (where you download m8) where you can read about the specs.
    its very nice made and lots of fun to read.
    cheers Peter
    www.instagram.com/pele2010/
    #eachfilm01
    #pele2010
    www.eachfilm.de
