Earth's surface on a sphere
  • Julien94
    by Julien94 » Fri Jun 28, 2024 4:20 pm
    Hello everyone,
    I want to create an interactive digital globe.
    For this I have two projectors and a 50cm styrofoam ball at my disposal.
    At the end you should be able to rotate the globe with a Playstation controller.
    So far so good, with one projector it's no problem at all. I created a 3D sphere and loaded it as an obj into MadMapper and placed the texture over it and adjusted the controller settings.
    But how do I do this with two beamers so that as much of the earth's surface as possible can be displayed?
    How do I have to align the two projectors so that there is a seamless transition of the earth's surface? Is this even possible with the distortion on a sphere?
    Thank you!
    best regards
    Re: Earth's surface on a sphere
    by franz » Mon Jul 08, 2024 10:42 am
    could do with some warping and a lot of trial and error.
Users browsing this forum: No registered users and 60 guests
