HOW to "CUT" instead of fade between groups?
  • pixel8
    by pixel8 » Tue Jul 08, 2008 4:24 am
    Hi all,
    Maybe a very basic question, but how do I cut between the groups?
    I'm actually trying to midi-map my Behringer controller so that I can asign a button to group A and group B, similar to the way the A/B transformer buttons work on the V-4. Is this possible?
    Any help really appreciated as the gig is tomorrow!!
    Cheers,
    wygiwys
    by wygiwys » Tue Jul 08, 2008 10:15 am
    If you use the beat (global) and select the fader, and then use the 'cut', it will cut. But this is not how you mean to do it.
    What You Get Is What You See
    WYGIWYS.tv
  • Lupin
    by Lupin » Tue Jul 08, 2008 9:47 pm
    Sigma did a module for this feature it's called (s6) Cut (all) Module
