MIDI Damper output signal is unstable
  • hector9
    by hector9 » Tue Jul 09, 2024 12:04 pm
    Hello, When using a Midi signal as input the damping filter when at high damping values ​​the output signal becomes continuous noise and it feels like the damping is multiplied.
    Has anyone encountered the same situation as me and was able to handle it? Thank.
    Re: MIDI Damper output signal is unstable
    by franz » Tue Sep 03, 2024 9:38 am
    lower the damping/hardness values then...
  • play.vj
    by play.vj » Thu Feb 06, 2025 2:45 pm
    Yes I noticed this also... the above solution actually works for all the Mad Mapper bugs, if there is some functionality that doesn't work just don't use it. Perhaps consider not using Mad Mapper at all :)
