MadMapper 5.6 release
    by MADben » Fri Jul 26, 2024 1:51 pm
    Dear mappers,
    MadMapper version 5.6 is now available, bringing a handcrafted collection of 40 atmospheric Laser materials, a global Color Palette, Response Curve for controls and more summer surprises to discover below :)
    You can download it on the website / user account / download section
    We're very proud of the new features, we hope you'll love them too!
    5.6 Full Release Notes
    ADDITIONS
    + Added support for media multi-selection: edit, duplicate and delete multiple media at once
    + Controls:
    + Added a checkbox to enable / disable Controls
    + Added an option to setup a custom Curve transform in Controls
    + Handle multi-selection / edition of Controls
    + MadLaser: Added a collection of 40 atmospheric Laser Materials
    + Added Color Palette as an option in all color parameters, color palette is editable from Master tab and global for the project
    + Added options in surfaces contextual menu in output preview: Enable/Disable Perspective, Match Media Size & Match Media Ratio
    + Handle editing a multi-selection of Modules
    + Calendar Scheduler module: added control to send an OSC string with an ICS file path to load
    + Added Generator "Chrono"
    IMPROVEMENTS
    * Update NDI to version 6.0.1
    * Button grid settings allows to create controls for each button separately now
    * Handle editing Input geometry (position/size/rotation) of a multi-selection of surfaces
    * ArtNet output now uses a fixed framerate to fix compatibility with some devices on the market
    * Made selected Mesh Warping handles more visible
    FIXES
    - Fixed possible network issues on Windows that could affect ArtNet, sACN (when controlling lots of universes) or Ponk (MadLaser) when sending lots of content
    - Fixed soft-edge size issue for video surfaces (when using Auto Setup)
    - Fixed soft-edge after adding mesh warping points
    - Fixed various Video-Output bugs when Destination had sub-screens
    - Fixed Testcard on Video-Output's preview
    - Fixed splash-screen (Windows)
    - Fixed control surface with Launchpad X
    - Firmata: fixed sending value on project load if output/servo/pwm value == 0
    - Fixed possible issue playing a movie when audio track ends before video track
    - MadLaser / Ponk: improved handling packets when network is not perfect
    - Fixed possible issue with Laser Surface soft close color
    - Fixed moving a multi-selection of surfaces with SHIFT key pressed (contrained move)
    The MAD Team.
  • CosmicZ
    Re: MadMapper 5.6 release
    by CosmicZ » Mon Jul 29, 2024 1:46 pm
    I acknowledge that it is my own fault, and that I shouldn’t have upgraded to a beta :shock: but is there a trick to get 5.6 running on macOS 15?
  • Simon_Holden
    by Simon_Holden » Tue Jul 30, 2024 6:31 am
    Editing materials isn't working right for me, I can change the code, but it doesn't seem to update the shader itself. I've reverted back to 5.5.5 where it is working fine.
    by mad-matt » Thu Aug 01, 2024 2:16 am
    We're not aware of any issue with macOS 15. What's your problem ?
    I can't reproduce the issue. Are you editing a Material or an FX ?
  • CosmicZ
    by CosmicZ » Mon Aug 19, 2024 10:10 am
    Hi Matt
    I'm still not able to launch MM (5.6.0) on MacOS 15 beta (24A5320a) as it hangs. Probably a trivial thing with a settings file or permissions but I can't figure it out.
    What kind of log/dump could I provide that would make it easier to understand what's happening?
    Best
    Screenshot 2024-08-19 at 10.05.48.png (82.98 KiB) Viewed 9908 times
    by mad-matt » Wed Aug 21, 2024 3:36 pm
    We made a fix in MadMapper 5.6.2, until we switch to 5.6.2 on the server, I PM you a 5.6.2 build.
    by mad-matt » Fri Aug 23, 2024 10:39 am
    Version 5.6.2 is out with a fix for macOS 15 beta + other fixes.
  • stepleader
    by stepleader » Fri Oct 11, 2024 5:29 pm
    Hi Matt can you also send me 5.6.2 I am in the same boat running macOS Sequia 15.0.1 (24A348)
Users browsing this forum: Google [Bot] and 18 guests
