Newbie ... sorry
  • StephanBergmann
    Newbie ... sorry
    by StephanBergmann » Sun Sep 01, 2024 10:55 am
    Hi all...yepp, I'm a total newbie.
    Question: I just want to make a playlist of 10 MP4 videos on a simple cue list that when pressing a button or a pad on a novation launchpad, it jumps or starts the next video in the cue with a transition effect. Output for test issues in the floating window on my MacBook, later on Projector.
    When I add the videos to the cue list, although they are 5 or 7 or 8 or ... min long, after 5 sec it's jumping to the next one. Sometimes I see them on the right playback window, sometimes not.
    Pressing the start button (changing to blue) above the scene/cue list, nothing happens....
    I'm a little confused....Or I'm stupid or the software is far more complicated than I thought (Qlab is in comparison very much more straight forward).
    Thanks in advance for any help.
    Cheers, Stephan
  • syntheticlives
    Re: Newbie ... sorry
    by syntheticlives » Sun Sep 01, 2024 7:52 pm
    I think scenes are automatically set to play 5 seconds. If you look in your scenes/cues window, in each square you have content, at the top right it says "Auto." Click that and it will pop up a menu that lets you adjust how long the scene holds for. The bottom selection will play the scene the length of the media and then jump to the next scene.
    Good luck!
