Playback stuck & Blackmagic issue
  • kevw8504
    by kevw8504 » Thu Sep 05, 2024 6:05 am
    I have noticed an issue on several of our Apple silicon machines which include M1 Max, M1 Ultra, M2 Max, M3 Ultra.
    What happened is a cue is triggered and the media won’t playback, if I toggle the hardware acceleration on and off it will begin again, but eventually after cues are triggered it may happen again.
    If the media does this I can also close the app reopen and it will work for a while but the behavior will eventually return.
    All our media is Apple ProRes usually 4k 5k or 6k resolutions. Any ideas?
    Additionally we have been unable to get our Blackmagic Design UltraStudio 4K Mini to show up in madmapper on the last few versions on any of our machines.
    Kevin Winkler
    Founder / Chief Innovation Officer
    812-444-9515
    kevin@blockhouse.media
    Re: Playback stuck & Blackmagic issue
    by mad-matt » Thu Sep 05, 2024 9:00 am
    Hi
    On macOS by default ProRes is decoded with AVFoundation (hardware acceleration turned on). When the issue happens do you have hardware acceleration turned on ?
    Could you send me (private message) a sample file that reproduces the issue ?
    I asked a collegue to check your BlackMagic issue.
    by Pierre Guilluy » Fri Sep 06, 2024 10:20 am
    What version of Blackmagic Desktop Video are you using?
    What version of MadMapper & macOS are you using?
  • kevw8504
    by kevw8504 » Fri Sep 06, 2024 8:46 pm
    We are all up to date using
    14.6.1 Sonoma
    MadMapper 5.6.3
    Desktop Video 14.2
    UltraStudio 4K Mini via Thunderbolt 3
    Issue the same on a
    M3 MacBook Pro Max
    M2 MacBook Pro Max
    M1 Mac Studio Ultra
    Kevin Winkler
    812-444-9515
Users browsing this forum: Google [Bot] and 17 guests
