Lost my undocked Cue Window
  • d4damager
    by d4damager » Wed Sep 18, 2024 3:54 am
    I place the Scenes/Cue window into a 2nd monitor and guessing I closed MM. Now that I'm on a single display, if try to undock, it's nowhere to be found.
    Re: Lost my undocked Cue Window
    by Pierre Guilluy » Wed Sep 18, 2024 2:54 pm
    You can just select "Scenes & Cue" in the bottom panel of the main window to bring it back.
    Screenshot 2024-09-18 at 14.54.00.png (8.36 KiB) Viewed 8857 times
  • d4damager
    by d4damager » Fri Sep 27, 2024 11:21 pm
    I’m aware I can re-dock it. The issue is trying to undock.
    by mad-matt » Mon Sep 30, 2024 11:16 am
    We solved this issue in MadMapper 5.6.4. I send you a version through private message. Sorry for this issue and thanks for reporting !
