Osc commands from third party
  • Declanone
    by Declanone » Thu Sep 19, 2024 10:49 am
    Hi everyone,
    I'm having trouble trying to send OSC commands via a third party osc sender (another computer) to madmapper.
    I know the computer madmapper is on is recieveing OSC because we have another software than can read incoming messages.
    The port is 8005
    And the IP is 293.268.1.100
    We can get other devices to talk to it by having a float osc message, however I am strictly limited to String or Integer from the program outputting.
    The program requires the following to send out:
    Mode:String/Integer
    Address: (the command)
    Type: String/Integer
    Argument: outcome
    So for example we tried:
    String
    Address: "surfaces/main/output"
    Type: ",i"
    Argument: "0" (or 1)
    This was asking the madmapper software to simply turn on and off a surface (so we can control the output).
    All we want to do is be able to send a command to turn on and off the surface or main layer even.
    Any tips, tricks, or insights into this?
    Thankyou in advance!
    Re: Osc commands from third party
    by mad-matt » Mon Sep 23, 2024 9:24 am
    Does it work if you close the other application receiving OSC before starting MadMapper ?
    If the other application opens the OSC port without "sharing options", MadMapper will fail to open the OSC port. It would be reported in the log file
    MadMapper supports integer or string OSC messages, but sending a string value on a parameter like surface opacity would have no effect.
    What happens if you use menu Edit / Edit OSC Controls, click a surface opacity slider, and send the osc integer event from your sending app ? Does it create a control ?
    by franz » Tue Nov 12, 2024 12:50 pm
    adresses start with a slash
    "/surfaces/Quad-1/...."
