Mad mapper wrong colours but white ok (solved)
  • nirduncan
    by nirduncan » Tue Oct 08, 2024 12:33 pm
    Hello
    So I have three towers of COB 24v rgb pixel tape. Running from an ESP32 (quinled dig octa) running WLED. Each tower has it's own data line and has about 350 pixels.
    In WLED everything works correctly.
    When I set up the fixtures in mad mapper. The white works normally but at the very top of the first tower, part way through a strip and fixture on mad mapper. The colour is differemt. Like if it should be red it's greeen.
    Then on the second tower the colour is diffent again and it changes again. On tower three the colour returns to normal mostly.
    I checked that all the fixtures are RGB. Interestingly if I change the affected areas to a different colour model it does fix the issue. But it will be a right pain to do. And I'd rather find out the actual issue.
    I've set up everything from scratch on the software side twice. Same issue.
    Thanks
    Neil
  • nirduncan
    Re: Mad mapper wrong colours but white ok (solved)
    by nirduncan » Thu Oct 10, 2024 10:29 pm
    OK so fixed my own problem. It was to do with the channels on the universes overlapping. Some how I made the same mistake twice in exactle the same way.
