Webm VP9 with alpha on Windows
  • amongconsequently
    by amongconsequently » Thu Nov 14, 2024 12:23 pm
    I am trying to use webm VP9 files with alpha in MadMapper, the alpha channel works fine in the browser and other apps supporting VP9, but ends up as black in MadMapper. I am converting my files with ffmpeg and tried both standard and yuva420p pixel format.
    Is VP9 transparency supported at all in MadMapper?
    Re: Webm VP9 with alpha on Windows
    by mad-matt » Wed Nov 20, 2024 4:21 pm
    Can you share a sample file ? (you can share it in PM)
    That must be easy to fix.
    at the moment you can convert your file to HapQ Alpha with ffmpeg or Adobe, or ProRes 4444.
