Internal DMX triggering
  • whagan
    by whagan » Fri Nov 15, 2024 2:27 am
    I'm trying to trigger Madmapper cues via artnet dmx between lighting software and MM on the same Mac. Capture (simulation software) is receiving Artnet signals via art net from my lighting software (SBA) but Madmapper is not. I launch the console first then MM. no luck, any ideas? Tried using Broadcast and unicast on the SBA app. (Capture works with broadcast)
    Re: Internal DMX triggering
    by mad-matt » Wed Nov 20, 2024 4:19 pm
    Did you choose the right network interface & universe in MadMapper preferences / DMX ?
    MadMapper allows sharing ArtNet port with other apps, but if Capture is not it would prevent MadMapper from opening the ArtNet port (if running on the same machine). Did you try starting MadMapper with Capture not running ?
    Also some apps / hardware starts numbering ArtNet universes at 0, others at 1. MadMapper starts at 0 (first ArtNet universe has number 0, like in a GrandMA for instance). Are you sure you chose the right universe in MadMapper DMX input preferences ?
