Rotate image from a specific point
  • dipifr
    by dipifr » Thu Dec 05, 2024 2:14 pm
    Good morning,
    I would like to move the hands of a clock. For this, I put an image of a clock and I separated the 2 hands (hour and minutes) into 2 separate PNGs. Unfortunately, I can't change the pivot point so that it's the base of the image that rotates and not the middle of the image. I use MadMapper 5, do you have any advice for me? Thank you in advance
    Re: Rotate image from a specific point
    by mad-matt » Sun Dec 08, 2024 2:59 pm
    Make your image so the center of the clock is at the center of the image (with alpha layer so it's transparent ouside the hands)
