Remove media from surface / clear surface
  • mw/mf0
    by mw/mf0 » Mon Dec 23, 2024 2:29 pm
    I might be blind!, but I can't find out how to clear a surface. Once a media is running but you don't want to see it any longer. There is "apply", but no "clear" or "remove"?!
    What am I missing?
  • littlejohn
    Re: Remove media from surface / clear surface
    by littlejohn » Sat Jan 04, 2025 2:29 am
    As far as I can tell there is always a media applied to a surface, when you create them they generally default to the last selected media or the testcard.
    If you want to blank out the surface then there are many options.
    Create a media which is literally just a black solid colour and use that.
    Save a cue to change the surface opacity down to 0%
    Hope that helps!
