5.6.6 on Apple Silicon Audio Master (level) not doing anything
  • Brian_WPG
    by Brian_WPG » Tue Feb 11, 2025 9:25 pm
    I've tested this on multiple different installs, all Apple Silicon though (either M4 Mac mini, or M1 Max Mac Studio) in every case, changing the Audio Master has no impact on the actual output volume no matter what output source is set in either MadMapper or OS level.
    Changing the volume on the media file itself (standard .mp4 video) does work - but in this particular case, we are using the Link Audio Level to surface opacity as part of switching videos on the fly on a trigger from an external source - but also want to adjust the volume level on the fly
    one of our team had a 5.3.4 demo version installed and the audio master level control is working on that one - so I'm going to go back through earlier versions I have downloaded to see if I can find any that do work to see where the bug maybe showed up - but it's kind of a pain to do this with the licensing
    Re: 5.6.6 on Apple Silicon Audio Master (level) not doing anything
    by mad-matt » Thu Feb 13, 2025 6:53 pm
    It doesn't work when the movie is played with AVFoundation Player, disable the "Use Hardware Acceleration is Possible" on your movie so it switches to FFMPEG player and then MadMapper takes control of the audio output. Please confirm this solves.
  • Brian_WPG
    by Brian_WPG » Thu Feb 27, 2025 11:02 pm
    Thank you, this did work.
    As soon as hardware acceleration is disabled on all of the videos, then the Master Audio control changes actually changed the audio output from the computers.
    Sorry for the delay in responding, didn't see it right away, then also couldn't make the change right away on the running exhibit.
