Custom Cues Confusion
  • philcho
    by philcho » Mon Feb 17, 2025 11:23 pm
    Hopefully you might help me?
    I have 1 LED Strip Fixture. I have 5 banks of Scenes, each bank has 3 or 4 scenes. I simply want to have a keyboard command that switches the "Bank 1" or "Bank 2" and then "Auto-plays" through each scene in that bank, looping.
    I can do this manually (clicking with a mouse) ok. But when I am (in Control List) setting up a cue: I choose "+" > cues > Bank-1 > auto_play and assign it to a key command, it doesnt always play correctly. It 'seems' fine if there is only one cue, but once I get them all in there and try to jump around, they dont seem to trigger correctly. Am I misunderstanding how this is supposed to work? There seems to be some odd logic with how the auto-play works - sometimes it stays on unexpectedly?
    Thank you again for your help.
    Re: Custom Cues Confusion
    by mad-matt » Tue Feb 25, 2025 8:59 pm
    You can also use two "Cue Scheduler" modules, and activate one or the other, to playback cues from a particular bank, instead of using the "Auto Play".
    We're not aware of such issue. Can you send a mail to support@madmapper.com explaining your issue ? We'll have a look.
    Are you using the "Switch on movie loop end" option to playback a movie once then switch to next column ?
    We've been working hard to make things more powerful to sequence cues in MadMapper 6, you can also have a look: https://www.youtube.com/watch?v=K5678-aQAcc
