info
  • cuddy
    info
    by cuddy » Sun Jul 13, 2008 8:16 am
    hi
    does anyone know how to set up the behringer bcf2000 with modul8
    so i can use the midi controler
    thanks
    cuddy
  • mowgli_uk
    by mowgli_uk » Mon Jul 28, 2008 5:02 pm
    plug it to your mac using a usb cable. Plug it to the mains, switch on, switch on your mac, open modul8, map controller to interface, enjoy.
  • Lupin
    by Lupin » Mon Jul 28, 2008 6:57 pm
    you need to use factory setups and beta version of bcf module to work with motorized sliders.
    if you don't care about this feature any usb midi controlers works the same in modul8 plug, scan midi device ( if you plugged the controller after you started modul8) then open the midi map and bind whatever you want .
