Multichannel Audio for Montage video tracks?
  • nassor
    by nassor » Sun Mar 30, 2025 8:56 pm
    Hi all, I'm trying to use the awesome new Montage feature to play a bunch of video sources in sync, one of which has 4 channel audio that must be totally synchronized with its video, since this is on-camera dialog. I understand this is doable via a separate Montage audio track - tried it and it works - but was hoping to play the built-in audio from the source video file, which would ensure everything stays synchronized over long playback time, interruptions etc. This works great with the regular video source but once I drop it into the Montage timeline I see now way to turn the audio back on. Many thanks, would appreciate any help on this!
    nadav
    Re: Multichannel Audio for Montage video tracks?
    by mad-matt » Wed Apr 02, 2025 9:49 pm
    Hi, when you select an media clip, in the media inspector (from media bin) you can enable audio playback, like for any other movie
  • roseblack
    by roseblack » Thu Aug 21, 2025 8:43 am
    Hi, when you select an media clip, in the media inspector (from media bin)Retro Bowl you can enable audio playback, like for any other movie
    If the video has multiple audio channels (e.g., 4 channels), when played in Media Inspector, does it play all channels, or just stereo?
    by mad-matt » Tue Sep 02, 2025 4:43 pm
    It will play all channels as long as you have enough channels in your audio output device selected in preferences
