Exclude parameters from Timelines
  • Zoltan
    by Zoltan » Wed Apr 02, 2025 9:23 pm
    it's probably a basic question, but I wish to exclude some parameters of the timelines bank.
    For example the color attributes of layers.
    I found a solution tricky solution by : Press record, Mute in the timeline the Color parameters and then doing a cancel action.
    But it's probably not the way to do it ?
    thank you
    Zolt
    Re: Exclude parameters from Timelines
    by mad-matt » Wed Apr 02, 2025 9:48 pm
    You can select all timelines (click one and press Ctrl+A / Cmd+A), then in the timeline editor search field type "color", select all tracks to remove and press Delete. That will delete all selected tracks from all timelines.
  • Zoltan
    by Zoltan » Thu Apr 03, 2025 10:44 am
    thank you Mat'
    I was looking for some right click.
  • Zoltan
    thank you Mat'
Users browsing this forum: No registered users and 80 guests
