Dmx : color selection not working
  • Zoltan
    by Zoltan » Sat Apr 05, 2025 2:39 pm
    I’m using the Cameo Root Par 6 with Beta 6. All the sliders are working correctly, but the color selector seems to be unlinked to channels 4, 5, and 6. If I change the color in the DMX monitor nothing happens.
    When I use the individual sliders instead of the RGB color selector, the LED PAR works as expected.
    Hope that makes sense—let me know if you’d like a short video to illustrate the issue.
    Best,
    Zolt
    Re: Dmx : color selection not working
    by mad-matt » Tue Apr 08, 2025 11:53 am
    Hi Zolt,
    Sorry for the late reply. Can you send me your project file in private message ? I'll check that. I can't reproduce your issue actually.
    Matt
  • Zoltan
    by Zoltan » Tue Apr 08, 2025 3:38 pm
    even with blank project I get the same behavior
    Here are two small videos https://drive.google.com/drive/folders/ ... share_link
    one for mm5 one for mm6
    Maybe I'm missing something with mm6 a new configuration ?
    by mad-matt » Fri Apr 11, 2025 11:21 am
    Ok. In MadMapper 6 the DMX Fixtures are sampling the pixel below it in the output preview. So you have to put a video surface with some visual on it, if not indeed it will be black
  • Zoltan
    by Zoltan » Sun Apr 13, 2025 6:10 pm
    Ok, it's working.
    What is the advantage of this new behavior ? something around "led screen" ?
    by mad-matt » Mon Apr 14, 2025 10:57 am
    You can mix from a visual do another or do compositions with multiple video layers.
    You can also create a bunch of DMX Fixtures lines, select them and choose "Create Lines from Surfaces Outlines" which will get you to nice effects fastly.
    You can see all your fixtures at the same time, even if you apply different visual content on different fixtures.
  • Zoltan
    by Zoltan » Wed Apr 16, 2025 9:55 pm
    thanks I get the idea.
Users browsing this forum: No registered users and 52 guests
