syncing multiple madmapper on multiple pc
  • sblim512
    by sblim512 » Fri Apr 11, 2025 8:28 am
    I am currently using 3 PCs each connected to multiple projectors.
    PC#1 projects to the ceiling
    PC#2 projects to the wall
    PC#3 projects to the floor
    I have multiple input source videos for each PC's coverage area
    ceilingVideo\video01~06
    wallVideo\video01~06
    floorVideo\video01~06
    I am using movie folder player and OSC control on playback position
    to sync each pc's madmapper project's playing video
    However, when the PC#1 finishes the first video and plays the next,
    the slight delay sometimes causes
    other PC's video position to reset to 0 before moving on to the next video.
    PC#1 is playing video02
    and PC#2, PC#3 are still playing video01
    Is there a way to setup to make sure all 3 pcs are playing the correct video?
    Re: syncing multiple madmapper on multiple pc
    by mad-matt » Fri Apr 11, 2025 11:20 am
    It's still in beta but if you use MadMapper 6 you can put your movies in a Montage track of the conductor, instead of using the Movie Folder Player module.
    Another option to avoid using the beta version is to make a single movie containing the movies you use in the Movie Folder Player.
