MadMapper v6 Beta 9
    MadMapper v6 Beta 9
    by MADben » Wed Apr 30, 2025 4:00 pm
    Hi mappers,
    MadMapper v6 BETA 9 is now available for testing, free for v5/v6 owner - https://madmapper.com/myaccount/downloads
    Any feedback or bug report are welcome !
    The MAD team.
    MadMapper 6.0 Beta 9 Release Notes
    ADDITIONS
    + Added Audio Routing on movies & montage tracks (multi channel input / multi channel output => routing matrix available)
    + Added project settings for Timelines
    + Added option to replace a Material / Generator etc. with another on a visual in Media Bin (right click / Replace ...)
    + Added Windows Audio System as audio driver type option in preferences
    IMPROVEMENTS
    * Optimized DMX Output with many universes
    * Optimizations in Audio processing
    * Timeline:
    - Improved edition of Media Clips in Timeline Montage Tracks
    - When adding a key frame and mouse if closed to value curve, adjust
    - Change timeline header display when changing quantization (to bars / frames)
    * Play does continue playback from where it was when paused
    * Handle Alt + drag to duplicate selection
    * When changing artnet network interface in preferences, update unicast table (no need to validate preferences first)
    * MadLaser:
    * Update ShowNET library (solves an issue after unplugging / replugging network cable)
    * Added "Paste Value" in widget right click
    FIXES
    - Fixed possible issue in Video Output loopback / spout / ndi on Windows depending Display Scale
    - Fixed restoring equalizer settings on application startup
    - Fixed reloading v4 generators
    - Fixed color interpolation
    - Show disabled tracks in timeline player clip subtracks
    - Fixed issues in timeline recording / edit mode (undoing mostly)
    - Fixed some issues reloading old versions projects
    - Support standard ISF long declaration (“VALUES” & “LABELS”)
    - Fixed Open DMX USB flickering on Windows
    - Fixed recording surface color attribute in timelines
    - Fixed an issue in Laser Quad with mesh warping & input mesh enabled
    - Fixed audio glitch when timeline marker follow action continue is triggerred
    - Various fixes in timeline
