MadMapper 5.7 BETA: introducing MadAI
    by MADben » Thu Jun 12, 2025 6:42 pm
    Hi mappers!
    We’re very excited to unveil MadMapper version 5.7 BETA, bringing Artificial Intelligence inside MadMapper!
    Meaning for instance you can use MadAI to create parametric realtime visuals without knowing how to code. It is simply magical!
    This built-in feature will help with the creation of  Materials, Laser Materials and also Surface 2D FX.
    You can even remix existing content from the Library with our AI system.
    All of that without code knowledge.
    Still, check out the MadMapper Youtube, filled with fresh new MadAI tutos!
    Free credits !
    MadAI requires credits to process a prompt. Each credit allows for one prompt.
You can buy credits on ‪www.madmapper.com/extensions/madai‬
however we've made a Redeem Key for every one to claim some free credits !
    To use the RK, simply login to your account, and under licenses, in the RedeemKey input box, enter the following code: RK_MADAI_FREE_CREDITS
    Don't forget to hit that big red beta button in the app to send us your feedback!
    Thx!
    The MAD team
    5.7 Beta Releases Notes
    ADDITIONS
+ MadAI: MadMapper AI to generate visuals (Materials & Laser Materials) or Surface 2D FX
    IMPROVEMENTS
* Optimized DMX Output with many universes
* Updated ShowNET library to handle properly network disconnections / reconnections
    FIXES
- Fixed possible issue with Open USB DMX on Windows
- Fixed ISF compatibility with standard "long" type in INPUTS
- Fixed issue with Laser Quad when using mesh warping in input
- Fixed generating lines surface geometry in some cases
- Fixed posible uv issue with mesh warping + mask feathering (use intersections with mesh warping segments)
  • BN visuals
    Re: MadMapper 5.7 BETA: introducing MadAI
    by BN visuals » Thu Jun 12, 2025 10:55 pm
    This is amazing!
  • jenniekim
    by jenniekim » Wed Jun 18, 2025 8:59 am
    Wow, MadMapper 5.7 BETA with built-in AI sounds like a Speed Stars total game-changer! Love that you can create stunning visuals without coding. Can’t wait to dive into those MadAI tutorials on YouTube and start experimenting
