MadMapper 6 BETA 13
    MadMapper 6 BETA 13
    by MADben » Tue Jul 15, 2025 10:28 am
    Hi mappers,
    We released the v6 BETA 13 available here : https://madmapper.com/myaccount/downloads
    We hope you'll like its bunch of additions and fixes,
    Please share any feedback or bug reports too!
    The MAD team.
    v6 BETA 13 release notes
    ADDITIONS
    + Added a project export function
    + Timeline:
    + Restore Cues & Scenes properly: a timeline is an animated Cue, create a Cue or a Scene and press animate to ad keys in time (avoids unwanted changes in time while working in Cue mode)
    + Audio, Montage & Timeline Clips can be moved from track to track
    + Added a button to change play/pause mode in editor (restart playback from time marker, or just continue where playhead is paused)
    + Shortcut Cmd/Ctrl + Shift + "+"/"-" to zoom vertically
    + Added right clip on Montage Clip / Replace Visual...
    + In Timeline Export, user can set a file name for each output (video & laser)
    + MadLaser:
    + Added Laser Circle surface type
    + Implemented laser mask feathering (on Laser Quad & Laser Output)
    + Added pincushion transform on Laser Output
    + Added laser Generator "Laser FX" to apply a Laser Line FX to a vector source visual
    + Added Svg Image player (add image / choose an SVG file) => you can get a vector input with colors for lasers surfaces and a adjustable size SVG for video surfaces
    + Added a way to re-enable discarded audio devices in Preferences
    IMPROVEMENTS
    * Improved MadAI History Management
    * Improved adding Library resources to Favorites
    * MadLaser:
    * Keep showing laser output masks (if enabled) while showing Test Pattern
    * Optimized masking
    * Automatically unarm lasers after waking up machine from sleep mode
    * Timeline
    * Add timeline clip by double clicking in timeline player track
    * For data tracks, don’t send any value before first key frame
    * Disable Use Hardware Acceleration option for movie decoding on Windows (can be enabled from project settings), to avoid instability with some graphic drivers, and most of the time performances are not better at the moment
    * Identify garageCube USB DMX with index on Windows (reloading file was not relinking correctly after a reboot)
    * AVFounration Movie Player now redirects audio to the device selected in Project Settings
    FIXES
    - MadLaser:
    - Fixed reloading project settings depending on laser expert mode
    - Timeline:
    - Fixed a bunch of undo/redo issues
    - Fixed possible issue with movies in montage tracks
    - Fixed timeline export if audio device list changes while exporting
    - Handle "No All" for audio files that are not found
    - Fixed issue editing montage clip parameter
    - Fixed crash inspecting audio track if a clip is offline
    - Fixed possible first frame issue in video export
    - Fixed ILDA export precision + first movie frame in some situations
    - Fixed Montage Clip with materails when editing the material (adding / removing parameters, for instance with MadAI)
    - Fixed KEY ALL in montage clicks parameter groups
    - Fixed undesired cueing of trigger & event inputs when creating scene (or cueing an object)
  • Firefly_199x
    Re: MadMapper 6 BETA 13
    by Firefly_199x » Wed Jul 30, 2025 4:51 am
    When assigning file names for each output video & laser, is there a way to automatically include the timeline name or timestamp in the filename to help organize multiple exports from different timelines or scenes?
    Slope Game
