MadMapper Beta 16
    MadMapper Beta 16
    by MADben » Wed Aug 06, 2025 11:11 am
    Hi mappers,
    We released the v6 BETA 15 available here : https://madmapper.com/myaccount/downloads
    We hope you'll like its bunch of additions and fixes, plus the expiration date is extended.
    Please share any feedback or bug reports too! Thx!
    The MAD team.
    MadMapper 6.0 Beta 16 Release Notes
    ADDITIONS
    * DMX Fixtures:
    * Prevent unpatching the pixel of a fixture definition with a single pixel (makes no sense)
    * Make fixtures more visible in preview
    * Timeline:
    * Disable play/pause/stop for conductor when External Sync is enabled (Timecode)
    * Ensure conductor is activated when activating External Sync
    FIXES
    - Timeline:
    - Montage track with FFMPEG Movie player: fixed possible issue scrubbing in timeline with movie audio enabled
    - Fixed possible issue exporting timeline
    - Fixed handling "Restart" in montage clips
    - Fixed a possible issue when cueing geometry
    - Fixed showing feathering for Lines surfaces
    Additionally, the previous Beta 15 Release Notes
    ADDITIONS
    + Timeline:
    + Added audio analysis to add snapping points on audio clips key points + detect audio file BPM
    + Added "Reveal in Timeline Editor" on all widgets context menu / objects (next to "Select Timelines using this setting"
    + Added cell navigation controls (to jam in timeline moving left/right/up/down)
    + OSC Output / Project Settings: handle Bonjour discovery to auto adjust ip / port and automatically reconnect your external software
    IMPROVEMENTS
    * Timeline:
    * Don't handle grid exclusivity for timelines started from conductor
    * Optimizations
    * MIDI Out & OSC out modules use the devices setup in Project Settings
    * Optimized engine when working with many outputs
    * Optimized NDI input & output (improves working with many streams + avoids blocking engine while NDI is encoding)
    * Updated NDI SDK to 6.2.0
    FIXES
    - Fixed a movie decoding performance issue in FFMPEG player in some conditions
    - Fixed Control Surface module when multiple units of same device are connected (system might add a number suffix to MIDI device name)
    - In some cases application could become unresponsive if engine is consuming too much resources
    - Fixed possible issue with ASIO after fiddling in preferences
    - Timeline:
    - fixed re-enable automation when two timelines are playing same attr
    - Fixed finding back audio files used in timelines in some cases
    - LTC Sync audio channel : first audio channel should have number 1, not 0
    - Fixed handling strings in OSC Events track
    - Fixed annoying cursor jump when editing osc track address
    - Fixed restoring ExtSync LTC channel number
