How to send specific quad/layers from madmapper into madlaser
  • the-J-flex
    by the-J-flex » Sun Aug 24, 2025 5:34 pm
    Hello guys,
    Actually i'm trying to create some internal routing, i would like to send some individual quad/layers from madmapper into madlaser (so not the entire madmapper output). Is it possible? Can I assign some specific quads to separate NDI outputs for exemple and then assign them to madlaser? I also use Resolume in same time and I'm really struggling with routing in madmapper....Looking for a simple way to create internal separate ouptuts, can't find anything.
    Thanks in advance,
    J
