MadMapper v6 Beta 18
    by MADben » Fri Sep 05, 2025 6:05 pm
    Hi mappers,
    We released the v6 BETA 18 available here : https://madmapper.com/myaccount/downloads
    Come with many fixes and 80-days expiration date
    Please share any feedback or bug reports too! Thx!
    The MAD team.
    MadMapper 6.0 Beta 16 Release Notes
    ADDITIONS
    + Timeline:
    + Added control "update" to update a Scene or update startup values of a cue / timeline
    FIXES
    - Timeline
    - Fixed a possible issue when resizing clip
    - Fixed crash when updating a Scene
    - Fixed possible issue where edited timeline can no more be started
    - Fixed disabling auto follow when scrolling manually
    - Marker follow action "Pause" must pause exactly on the marker, so action "Continue" restarts playback
    - Some popup could stay opened on Windows
    - Fixed possible issue playing a Montage Track with transitions when some visuals are offline
    - Fixed issue with timeline player clips referencing deleted timeline
    - Fixed possible app freeze on windows when loading audio file with unicode characters
    - MadLaser:
    - Fixed issue with etherdream if started when ILDA frame is more than 4000 points
    - Fixed laser line texturing with different aspect ratio
    - Fixed slider with integer value when value is over 1000 (ie slider 16 bits)
    - Fixed an issue on case sensitive file systems
    - Fixed control /application/view/fullscreen after changing fullscreen mode manually
    - AVFoundation movie player: fixed handling audio level in some cases + fixed audio playback after changing system default output
    - Fixed sending Control feedback (osc, midi) for color (red, green, blue, hue...) when changed from cue / timeline
    - Fixed loading Online Library (materials etc) when not logged
    - Fixed starting MadMapper on macOS versions < macOS 13.0 (downgraded NDI library to version 6.1.1 at the moment)
    - Fixed fullscreen button state when loading project automatically enter fullscreen mode
    - Fixed possible crash when stopping NDI Output (introduced in 6.0.0 beta 15)
