Quad editting in Fullscreen mode, possible?
  • AgentD
    by AgentD » Thu Sep 18, 2025 5:46 pm
    Hi, I am faced with an issue which I believe many of you have also encountered.
    I have a minimac connected to a projector. Unlike laptop, MiniMac doesn't have any screen attached, therefore once I go "Fullscreen mode" I lose MadMapper interface and I can't really map the surface while I make adjustment to the Quads.
    Is there anyway that I can activate the selected Quads control on screen while in Fullscreen mode & turn that off once it's done? It is very frustrating and time consuming to go back and forth with fullscreen and desktop modes to map the surface.
    Please advise! Thank you so much in advance.
    Re: Quad editting in Fullscreen mode, possible?
    by mad-matt » Fri Sep 19, 2025 12:36 pm
    You can do that if you know the shortcuts: in menu Output, activate "Show Info", it will show surface handles in the fullscreen output. You can know manipulate the surface from the fullscreen.
    Alt+Click => add a warping handle
    Tab / Shift+Tab: select next/previous handle
    Alt+Tab / Shift+Alt+Tab: select next/previous surface (if in handle mode, selects first handle of next/previous surface)
    You can use keyboard arrow keys to adjust positions
Users browsing this forum: No registered users and 53 guests
