Change content with only USB stick or something....
  • barneyb
    by barneyb » Thu Oct 16, 2025 10:20 pm
    Read the manual, don't see a solution right away so......
    Suppose I make an installation with 32 Quads, name all the pictures /movies just pic-1, pic-2, pic-3 etc
    Read the content from an external USB stick. Client can change content by inserting new USB stick with new content that uses the same names pic-1, pic-2, pic-3 etc....or even better, upload it in a map.
    Would this be possible?
    Thanks in advance, Barney
  • barneyb
    Re: Change content with only USB stick or something....
    by barneyb » Fri Oct 17, 2025 9:26 am
    I do this on Madmapper in some projects (having content on seperate HD in that case) but not sure I can pull this off on Minimad the same way
    by MADben » Fri Oct 17, 2025 6:01 pm
    Indeed the Minimad is a "madmapper mapping player" meaning you can (only) display and even manage a bit mapping content that has been exported from MadMapper, either from a computer or via remote-export over ethernet
  • barneyb
    by barneyb » Sat Oct 18, 2025 12:08 am
    Hey Ben thanks for the reply. The only thing I like to know if content could be played from an usb flash drive that I can swap (yes with the same name for disc and files) so if client sticks to the rigt formatting of the titles they couldchange content without re-connecting to madmapper
