Synch madlaser with projection
  • Pspkcz
    by Pspkcz » Tue Oct 21, 2025 12:45 pm
    Hello maybe its was here already but i would like to ask too speed my process of learning..
    If I copy image which is projected, is there a FX which i can apply to make a border render ? than copy past it to the madlaser and synch laser with the projection ?
    something like this ?
    https://www.facebook.com/reel/1312047183783235
    I saw tutorial from madmapper on youtube of course , but the proces of do this should be easy ...like apply some fx in photoshop when you apply surrounded lighting in style of layer.
    please let me know
    thx Pospik
  • Pspkcz
    Re: Synch madlaser with projection
    by Pspkcz » Mon Oct 27, 2025 5:04 pm
    no reaction ?
    by franz » Mon Nov 17, 2025 11:08 am
    make 2 videos in after effects... one for the projection one for the laser, then play them in sync ?
    make 1 video containg both laser + projection, use the right portion from the input for each projector/laser ?
    make a material (using madai if you don't code) to output both the content for the video AND for the laser ?
    move the laser beam manually to follow the video, using mm6 timelines ?
