A bunch of ideas/wishes
  • TomHethro
    by TomHethro » Wed Nov 19, 2025 1:07 am
    Hey gang
    Love the software — MM6 Beta is looking excellent.
    A few feature requests and workflow improvements that would make a big difference in daily use:
    • Colour Picker
    The ability to sample colours directly from reference images or other parts of the UI
    • Multiple Colour Palettes
    Right now there’s only a single global palette. It would be great to create and save multiple palettes for different projects.
    • Rulers
    Would be cool to have rulers for design, layout, referencing (similar to after effects etc) that just should up in the UI and not the output.
    • Easier Surface Transform Controls
    More intuitive transform handles and snapping tools (similar to Figma or Resolume). I often accidentally move a single vertex when I intend to grab an entire edge.
    • FX Stacking
    The option to apply multiple effects on a surface, ideally with an expandable FX chain/window (perhaps on the right-hand panel). Often I want to combine simple effects like blur + contrast for more compositing control.
    • Effects on Media
    The ability to apply FX directly to media (blur, transform, mirror, etc.) before routing it to multiple surfaces.
    • Media Window Improvements
    A version of the media window that lives in the bottom panel alongside Scenes, Cues, Control List, Fixture Editor, etc.
    Being able to freely arrange, group, duplicate, and organise media—similar to Resolume’s deck layout—would streamline workflow.
    (I find the cue window a bit confusing, so a more flexible, visual media palette would help.)
    • Module Request: Step Sequencer
    Oscillators are great, but a step sequencer for generating control data (similar to VDMX) would open up a lot of creative possibilities.
    • Right-Click MIDI Learn
    A quicker way to MIDI-bind controls. Ideally “MIDI Learn” appears immediately when right-clicking any parameter, reducing the number of clicks.
    • Beta 6 – Right-Click Keyframe Automation
    Currently adding a parameter to timeline automation takes a few steps.
    Right-click > “Add Keyframe to Timeline” would feel much more intuitive (similar to Ableton), especially when animating.
    • MadLaser – Cue/Material Tools
    More flexible material-building blocks would be very helpful. Beyond’s cue-building system is great for designing buskable looks; MadLaser is powerful but harder to busk with in a live context. Stronger cue-building tools would make a huge difference.
    Some oscilllator-like laser tools would be great.
    Love the software, looking forward to MMv6!
    Thanks to the MM team.
    Tom
    Re: A bunch of ideas/wishes
    by franz » Thu Nov 20, 2025 10:00 am
    Thanks Tom for your insights.
    Actually a lot of these where already discussed internally, some for a long time already.
    Rulers,Picker, stackable MediaFX....
    Now that v6 is out, we'll try to focus a bit on Quality Of Life improvments.
