anyone use trigger finger here ?
  • timothy_boreale
    by timothy_boreale » Tue Jul 22, 2008 4:17 am
    i was use it , it is works fine with my mcp and m8
    but now , it is doesnt works with my mbp anymore ...
    i can not even find the midi driver in my mbp now ....
    anyone can help ?
    thanx !!!
  • strictly
    by strictly » Sat Jul 26, 2008 10:57 am
    try changing the usb cable, and try using it from only the right hand side port on MBP.
    I find that my trigger finger will not work on the left hand port of MBP. This is a documented problem. I also had trouble using trigger finger with Imacs, I would have to swap USB ports to get a signal.
    When I use it on the right hand side port of my MBP, I have no problems what so ever (sometimes need a rescan midi) Hope this helps.
    deepvisual
    by deepvisual » Sun Jul 27, 2008 12:25 pm
    strange but true.
    I had the same problem with BCR2000.
    seems the USB bus is powered well on the LHS but not on the RHS????
