MadMapper 6.0.2 Released
    by MADben » Fri Nov 28, 2025 8:12 pm
    Hi everyone,
    MadMapper 6.0.2 is out featuring numerous improvements and bug fixes, and available here for v6 owners : https://madmapper.com/myaccount/downloads
    If you’d like to try MadMapper 6, all licenses and upgrades are 25% OFF until December 2.
    A big thank-you for all your incredible feedback so far, and for your outstanding support at hunting bugs!
    MAD team.
    MadMapper 6.0.2 Release Notes
    ADDITIONS
    + Added an option to enable/disable auto patching of DMX fixtures when pasting/duplicating
    IMPROVEMENTS
    * Timelines:
    * Improved Export dialog
    * Added value range setup for OSC Float & OSC Integer tracks
    * Value clips can be dragged from a track to another
    * Added "Use Hardware Acceleration" option on Montage Track clips (usefull for ProRes playback on macOS)
    * Handle .heic image files (iPhones pictures)
    * DMX settings are restored at startup
    FIXES
    - Fixed relinking live inputs when loading MadMapper 5 projects
    - Fixed OSC Query after changing port
    - Timelines:
    - Fixed generating thumbnails with some movies
    - Fixed few issues with offline audio track or montage track clips
    - Fixed moving scenes by drag & drop
    - Fixed "Update Scene" in some situations
    - Markers were missing when duplicating a timeline
    - Fixed possible issue seeking in montage track clip in paused mode when audio track is activated
    - Fixed using same audio device for input & output on macOS
    - Fixed Surface 3D calibration handles display
  • skinnymon
    Re: MadMapper 6.0.2 Released
    by skinnymon » Mon Dec 01, 2025 11:26 am
    Anyone else having the issue where if you save a project made in 6.0.2 and try to reopen it that it suddenly becomes super laggy and bugs out?
    by mad-matt » Mon Dec 01, 2025 12:41 pm
    There is no such known issue. Could you send a mail to support[at]madmapper.com requesting for Matthieu with details of the issue and you project file ?
  • skinnymon
    by skinnymon » Tue Dec 02, 2025 10:08 am
    if you're recording the mesh warping as a keyframe is there any way for it to gradually change between scenes? seems to only have an abrupt change on the actual keyframe rather than gradually warping.
    by mad-matt » Sun Dec 07, 2025 2:41 pm
    Actually this is working if you don't change the warping grid size, so if just moving exsting points (not adding or removing)
  • gnomalab
    by gnomalab » Wed Dec 17, 2025 8:13 pm
    I just installed the latest version of MM 6.0.2 for Mac. I was doing some quick tests with the laser through Syphon. As always, I check the laser output points, and I noticed that it doesn't show any information about the points being projected. Likewise, the beam preview doesn't seem to be working either. I don't know if I need to activate something else, since the interface has changed quite a bit compared to the previous version I tested, which actually worked. I've captured a video to make it clearer.
    https://youtu.be/cQrV0JeU8cY
    Captura de pantalla 2025-12-17 a las 19.01.50.jpg (285.4 KiB) Viewed 813 times
    by mad-matt » Mon Dec 22, 2025 1:13 am
    Is the Laser Master at 0% ? The beam preview stops when master level is at 0%.
