(dm) Meidia Set Load
    danger
    by danger » Tue Jul 22, 2008 2:59 pm
    I have just started some new module to load media set's
    Is still on beta
    please comment here and warnm about buggy code :P
    is my first module so there is many things thst may not be made the best way
    special tnkx to lupin for some help
    PS: please create one folder "mediasets" on your home to work (this will be fixed on next release
  • queglay
    by queglay » Tue Aug 19, 2008 2:20 pm
    this is a good idea. im just getting into modulate and only being able to load 128 videos is a bit limiting for me. however, when i click play on the module, nothing happens.
    danger
    by danger » Wed Aug 20, 2008 10:35 am
    the module still is beta...i have a few new things to put in it
    if you need any help feel free to contact me on messenger
    msn: danger@hiperbock.org
    http://www.myspace.com/vjdanger
  • incuf
    by incuf » Sat Dec 27, 2008 8:42 pm
    GREAT MODULE!!!!!!
    This module it's going to change the way I prepare my sets. I rather have a lot of mediasets, than projects.
    good work!!!
    cheers
    IncuF
  • mowgli_uk
    by mowgli_uk » Sun Jan 11, 2009 10:08 pm
    Thanks a million! I'm loving it
  • Vibber
    step by step needed
    by Vibber » Wed Jan 21, 2009 11:16 pm
    yea this module sounds just like what I've been looking for
    But I need it spelled out, can't quite figure out how it works.
    Here's what I do please correct me where I'm wrong.
    I'm trying to create two sets:
    1. I create a folder /users/myname/mediasets
    2. I import some media in modul8
    3. in the save set name I type set1 and click the button no 1 below
    4. I delete my media and import some other media
    5. in the save set I type set2 and click the button 2 below
    Now when I click button 1 in load set I get the first media loaded and everything is great, but how do I get the media in set2. When I open your m8s file there is nothing...
    Hope you can help
  • incuf
    by incuf » Thu Jan 22, 2009 3:19 am
    Save sets numbers refer to mediasets. If you want to save a media set 3, you have to click on number 3.
    If you want to load a saved media set in modil8´s mediaset 8 , just click button 8 under "load media"
    So, if you load your clips in mediaset 1 and you want to save that set. you have to click on button 1 under "save set"
    I don´t know if this will help, as I don´t quite understand what´s your problem
    cheers
    IncuF
    Ropski
    let's have a try
    by Ropski » Thu Jan 22, 2009 3:47 am
    thanks for this module! let's see how it works out :)
  • Vibber
    by Vibber » Sun Jan 25, 2009 4:27 pm
    OK thanx now I get it. I didn't realize before that the numbers refer to the tabs in the media set window.
    This is very useful. Thank you.
  • mowgli_uk
    by mowgli_uk » Thu Jan 29, 2009 10:18 pm
    I'm seriously impressed and happy with this module, thanks again!
    Although I have to say that I'm also happy that it didn't exist from the start as I've developed a way of working with modul8 that probably wouldn't have happened had your module existed.
    Thanks to you now I have two distintct methodologies and styles to combine.
    :D
  • mikdog
    by mikdog » Sun Dec 26, 2010 12:44 am
    Nice Module man.
