DirectEvent strange error
    Roger
    by Roger » Thu Jul 24, 2008 5:52 am
    Hello!
    Just bought my Modul8, and was very happy with the scripting until I tried DirectEvent. It always shows an error that apparently shouldn't be there.
    I shortened my script to just this, so I can show the error:
    Code: Select all
    print 'param=', param
    message = param['message']
    param1 = param['param1']
    param2 = param['param2']
    print 'message=', message, 'param1=', param1, 'param2=', param2
    When I restart the module, the error window shows up complaining about line 2:
    Code: Select all
    Runtime error in "VaiVendo script" (DirectEvent) at line 2:
    KeyError: 'message'
    But the outuput on the console seems OK, the message variable is set:
    Code: Select all
    param= {'timestamp': 22866874564392.0, 'channel': 1, 'param1': 19, 'message': 'CONTROL_CHANGE', 'rawEvent': 176, 'param2': 127}
    message= CONTROL_CHANGE param1= 19 param2= 127
    If i try to get param1 first, it will complain about param1 and not about the others. The 1st param I try to get always give me this error.
    What is wrong?
    Is it a bug?
    BTW, i'm using Modul8 2.5.6
    Thanks...
    david
    Re: DirectEvent strange error
    by david » Tue Jul 29, 2008 11:39 am
    Hello Roger,
    Roger wrote:Hello!
    Code: Select all
    Code: Select all
    KeyError: 'message'
    What is wrong?
    Is it a bug?
    param is a Python dictionnary, but its content depends on the type of the received DirectEvent. So when you are receiving KEYDOWN/KEYUP messages, the dictionnary is not containing the 'message' value.
    So you could use something like this for parsing Midi direct event :
    Code: Select all
    if type == 'MIDI':
       print ' param=', param
    David
