MiniMad limited to 2??(SOLVED)
  • AgentD
    by AgentD » Thu Apr 23, 2026 7:02 pm
    I can't connect more than 2 MiniMads anymore for some reason. I have this installation that I need to output to 3 extended monitors. After exporting the video to MiniMad in SD card(following all the steps), for some reason 3rd output never works (see attached). MiniMads are connected through Ethernet. I have used multiple minimads so many times in the past with the exact same equipment but this is the first time I across with this issue. My mac is MacbookPro 2017 M1 Max. Please advise!
    SOLVED!
    It turned out that once I switched MM6 back to MM5 it worked out fine. Is this a known bug from MM6??
    Re: MiniMad limited to 2??(SOLVED)
    by MADben » Mon Apr 27, 2026 4:47 pm
    This is not a known bug but it might also be the first report of this kind...
    So it's hard to say more at this point. However, I don't know which version 6 you were using, but I'd suggest to make sure to use the latest version 6 available in the Downloads section. There have been quite a few versions with bug fixes recently
