Help needed, exported file FPS
  • paul_h
    by paul_h » Tue Jun 09, 2026 12:40 am
    Hi All,
    I am new to MadMapper, I thought to give it a try because of the fantastic timeline export feature in 6.0
    My plan is to generate the distortion in MadMapper and then distribute the clips in an array of syncronized players.
    I need a 25FPS output but all the generated video files happen to run at 60FPS, even if I set manual FPS in project settings>engine.
    FPS display in output>show info is steady at 25 so I suppose there is an encoding parameter somewhere I cannot find.
    Can you please help me?
    In this job consistence between input and output files is vital and re-encoding externally is out of question, as well as recording the output via Spout or OBS. I just need a clean, easy 25fps file.
    Paul.
  • paul_h
    Re: Help needed, exported file FPS
    by paul_h » Tue Jun 09, 2026 10:38 am
    Problem solved with the help of support.
    I missed the timeline settings tab. :oops:
