MadMapper Windows dual GPU: keeping all 4 outputs on an RTX PRO 6000 for projectors, Main Display on a second card?
  • Lumenarius
    by Lumenarius » Thu Sep 17, 2026 7:56 pm
    Long time MadMapper user here (15 years, since the Mac only days). I am about to order a dedicated Windows server for projection mapping and hit a question I want answered before I spend the money. Posting here so it is searchable for the next person too.
    The build:
    - AMD Threadripper 9970X on a TRX50 board
    - NVIDIA RTX PRO 6000 Blackwell Max-Q (4x DisplayPort)
    - Windows 11
    - MadMapper 5 & 6
    The goal: all 4 outputs on the 6000 go to projectors (4x 4K60, or 16x HD through Datapath FX4 splitters).
    The problem: Threadripper has no integrated graphics, so the motherboard has no video output for a desktop monitor. If the GUI monitor takes one port on the 6000 I am down to 3 projector outputs. The obvious fix is a second small NVIDIA RTX PRO card (RTX PRO 2000 or A1000) that drives only the desktop monitor, with every app pinned to the 6000.
    The catch is in the MadMapper 6 troubleshooting docs under Multiple GPUs (Windows):
    "If you do have multiple GPUs, be sure to set the Main Display of Windows Display settings to a screen connected on the most powerful GPU. MadMapper will do all the processing on the GPU attached to the main display. When we'll switch from OpenGL to Direct3D on Windows, multiple GPU support will be improved, although we can't say when this will be ready."
    So as I read it, if the desktop monitor on the small card is the Windows Main Display, MadMapper renders on the small card. Wrong GPU.
    Questions:
    1. Does processing follow the Windows Main Display even if the MadMapper window itself is sitting on the second card's monitor? In other words, can I set Main Display to a 6000 output, keep the GUI on the small card's screen, and have MadMapper render on the 6000?
    2. Is there any way in MadMapper 6 to choose the render GPU explicitly instead of it following the Main Display?
    3. Has anyone run this two card layout on Windows in practice, GUI on the small card and fullscreen output on all 4 ports of the big card? Did it work, and were there any surprises?
    Trade-offs I already see, for anyone reading this later:
    - If Main Display has to be on the 6000, that means Main Display is the projector Mosaic surface. New windows open there by default, so you need a way to pull hidden windows back to the GUI screen (Win + Shift + Arrow works if Snap is enabled).
    - If none of this works, the fallback is 3 projector outputs plus the desktop on the 4th. Not the end of the world but it costs a 4K output on a very expensive card.
    - The docs say multi GPU handling will improve after a move to Direct3D, with no date given.
    If anyone from the MadMapper team or anyone who has built a rig like this can chime in I would really appreciate it. I will post back with results once the machine is here and tested either way.
    Thanks,
  • MatteLe
    Re: MadMapper Windows dual GPU: keeping all 4 outputs on an RTX PRO 6000 for projectors, Main Display on a second card?
    by MatteLe » Mon Sep 21, 2026 8:41 pm
    In my understanding, you could use the interface on the pro 6000 and do ALL outputs on a smaller card (not sure if all outputs are framesync on the workstation cards, could be). At least I used this poor mans constellation with one rtx a4000 and some p2200 for having some edid locked outputs (but only poor wuxgas). The bus speed on pcie 5.0 is more than high enough for 4x4k60fps.
    by mad-matt » Tue Sep 22, 2026 9:02 am
    MadMapper 6 is still OpenGL based (we'll soon be native Direct3D/Metal). With OpenGL it's very hard to choose the GPU. Same with other OpenGL apps (ie Resolume etc.). It will start on the GPU the main display is attached to. You can set one of your projector output to be the main display (but the windows login menu might appear there then which might be annoying in some situations)
    If you just drive 4 video projectors at 1080p resolution, I advise you to use a video splitter like Datapath FX4 or cheaper alternatives (Matrox QuadHead2Go, Startech thing...) to send a 4k60 stream from one of your video card output and split it into 4x 1080p60 outputs. Then you run everything on a single GPU and avoid memory transfers from a GPU to another. Best is to try, with today's computer we have lot of bandwidth so memory transfers from a GPU to another might not be a problem.
  • Lumenarius
    by Lumenarius » Wed Sep 23, 2026 9:41 pm
    Hello everyone, and thank you for your input and for sharing your experience.
    The problem I'm trying to solve is getting the maximum number of 4K outputs out of an RTX PRO 6000.
    The original plan assumed a Threadripper or the equivalent Intel Xeon. Those CPUs have no integrated graphics, so the motherboard HDMI port is dead and the main display desktop monitor would have to take one of the four outputs on the 6000.
    To avoid that we seriously looked at adding a second GPU, such as an RTX PRO 2000, to drive the desktop monitor. It isn't clear from the documentation or from field reports whether that combination works reliably, or whether MadMapper (or any other app) would render on the 6000 while the 2000 owned the main display. Given the cost and how unproven it is, we decided it wasn't the path to go down.
    After talking with MAINGEAR, Puget Systems, and Falcon Northwest, we realized we could get everything we wanted with a consumer grade CPU such as the Intel Core Ultra 9 285K or the AMD 9950X3D2. Both have an integrated GPU on the CPU die. Enable it in BIOS, run the desktop monitor from the motherboard HDMI port, and all four outputs on the graphics card are free for projectors.
    We confirmed this on a desktop we already own: a Ryzen 9 9950X3D with an RTX 5090. With the monitor on the motherboard HDMI (the iGPU) as the Windows main display and MadMapper windowed on it, all the rendering still lands on the 5090, confirmed with nvidia-smi. Minimizing every window on the desktop monitor dropped the iGPU to about 1% while the 5090 held around 60%, which shows the iGPU is only presenting the preview and the work is where it should be. No configuration was needed inside MadMapper. The only setup was enabling the iGPU in BIOS. We have not yet tested an Intel iGPU with an RTX PRO 6000 specifically, and will post results when we do.
    We may test adding a second GPU later just to see what happens, but for now this combination solves the problem of separating the desktop monitor from the projector outputs.
    With enough GPU bandwidth that's four 4K outputs, so four 4K projectors, or 16 HD projectors through Datapath splitters. Obviously test all of this in the studio before it goes to the field, but 16 projectors from one machine is the Holy Grail, and MadMapper can do it given the right hardware configuration. That's music to our ears.
  • noirvi
    by noirvi » Fri Sep 25, 2026 8:32 am
    Nice solution with the happymod9950X3D. Are there any specific BIOS settings or Windows graphics preferences you had to tweak to keep MadMapper pinned to the main GPU?
    by franz » Mon Sep 28, 2026 9:40 am
    bitvisus has some multi screen splitters ofr 4k outputs.
    Haven't tried them personnaly tho'
    https://bitvisus.com/collections/8k-mul ... n-expander
  • bLackburst
    by bLackburst » Tue Sep 29, 2026 12:18 pm
    Sounds like the solution was the opposite of what the madmapper team and docs say? Given the results I'd be very interested to hear from them about it, i have an igpu output doing nothing too!
  • Lumenarius
    by Lumenarius » Tue Sep 29, 2026 10:17 pm
    @noirvi To get the 9950X3D working I did have to get into the BIOS and change some settings to enable it to work. Otherwise it was dormant out of the box. However, no special settings besides that were needed to ensure that MadMapper was rendering on the 5090 once BIOS settings had been completed.
    This makes sense and is as desired and I am not sure what levers could have been pulled had that not been the case. I think you can possibly using the Windows graphics settings or one of the NVIDIA Control Panels or Apps to assign specific programs to prefer running on a specific GPU but we did not go down that path
    It would be interesting to see what would be the case if a 2nd GPU was used for the Main Display Desktop Monitor.
    However, given the expense and complexity, and that the iGPU does the job well, we did not proceed with those tests.
    Additionally it would be interesting to see if it was possible to have dual GPUs of a high tier, like dual 5090's, then have MadMapper still run on the iGPU. That could theoretically give MadMapper x8 4K outputs, or an eye watering x32 HD outputs (using Datapath Fx4's etc).
    This would give a Disguise server a run for it's money at around $100k+ for a GX3+ which can only do x3 4K outputs. That is a test I hope the MM team would attempt and publish as it would set a new maximum theoretical limit on how many screens MadMapper could address from a single PC machine.
