MadMapper 6.2.0 Beta release
    by MADben » Fri Oct 09, 2026 3:00 pm
    Hi beta testers,
    MadMapper 6.2.0 Beta is available, free for v6 owners : https://madmapper.com/myaccount/downloads
    Featuring:
    -Notch files playback. You can now load your Notch Blocks directly into MadMapper, which will populate exposed parameters accordingly: control everything from the timeline, map the content on quads or use it to send DMX data. When it comes to demanding realtime graphics, Notch is simply one of the best toolkit around. You'll need a Notch license to run your blocks. Drag and drop your block into MadMapper and it will appear as a media. Windows ONLY.
    -Task editor to group Cues and play them back in a theatrical fashion. Group cues together to form a Task. Trigger tasks one after the other for theater shows. Just like a CueList.
    -Media pipe integration. Track hands, skeletons and faces via a dedicated Module. You can run multiple instances of the Module at the same time and track from different cameras or media.Built in DefaultEasing to smoothly interpolate parameters when no detection occurs. Perfect for your next interactive piece!
    -TouchDesigner integration. Simplify your setup and load your TOX files in MadMapper. The feature is accessible though a dedicated Module that will generate published textures (optional) and parameters. Note: that you'll need a TD license to run your .tox
    -WebMedia + WindowGrabber modules. Use any webpage as a media, and grab any application's window, directly into MadMapper.
    -Stackable Audio FX ! Supports VST3 and AudioUnits. Add FX on your audio track within a scene/cue, or directly on the master.
    -CIExy color sampling. The pros asked for it: CIExy color sampling now comes to DMX fixtures. No more manually converting values. And it's been used on Christopher Nolan's "The Odyssey"!
    Don't use it for production yet, but we would be happy if you could test it and send us your feedback ! Thanks!
    Happy mapping ;)
    The MadMapper team.
    MadMapper 6.2.0 Beta 1 Release Notes
    ADDITIONS
    + Added Tasks (big GO button to sequence a living show)
    + Added Notch support: load a block as a media (Windows only)
    + Added Touch Designer support: load a TOX as a module
    + Added Audio plugins support in master & audio tracks (VST3 + AU)
    + Added WebPage media: use any webpage as a interactive media
    + Added Window Grabber media: use any application window as a media
    + Show Sequencer (formerly "Timelines")
    + Conductors & Grids are split in different banks, a conductor can reference Scenes/Cues from any Grid bank
    + Added equalizer on timeline Audio Tracks
    + Added MadLight player track to playback recorded DMX sequences as clips in a track
    + Added OSC Query support as client to add osc tracks
    + Added "Audio Linked To Opacity" on montage clips
    + Added timeline start marker
    + Cue Grid can be flipped (to swap columns/rows)
    + DMX Fixtures
    + Added support for HSI & CIE xy color control
    + Added FPS mode option for ArtNet (Fixed FPS / Variable FPS)
    + Controls
    + Handle MIDI Controls specific to a MIDI device (from Project Settings / MIDI / MIDI Input / Mapping Device)
    + Added MadLight Player track to record / playback DMX Recordings (can record all incoming ArtNet in a clip and play it back)
    + You can now open a window to monitor incoming TimeCode when conductor uses ExtSync
    + Soft-Edge: added "black level compensation", used to hide the fact that projectors cannot produce a true black
    + Added Surface2D FX Ascii Art
    + Added Expert Mode features in Project Settings
    + Added an extract button in selected editor's toolbar
    IMPROVEMENTS
    * Increase User Interface contrast
    * Video Output / Laser Output destination popup now shows which screens/lasers are already in use
    * Improved constrained move (Shift+drag item in preview): handles multi-selection + supported for mesh warping items
    * Images are loaded only when used to reduce memory usage with hundreds of images + load asynchronously
    * Restore Preferences geometry when reopening it
    * Allow saving in Demo version (for testing only, so project files can't be shared between demo & licensed versions)
    * Added all combinations of RBG (RBG GRB ...) by default for LED Strips & LED Matrices
    * Added project export archive option
    * Updated Canon SDK to version 13.20.20.0
    * Better handling for audio routing of 5.1 / 7.1 audio channels movies to mono or stereo output
    * Optimizations handling huge projects
    * Updated Canon EDSDK to version 13.20.20.0
    FIXES
    - Don’t reset master settings when loading a file or when saving project for first time
    - Fixed reloading V5 project Cue Scheduler module parameter "bank"
    - Fixed exporting project in certain circumstances
    - Various bug fixes
  • gnomalab
    Re: MadMapper 6.2.0 Beta release
    by gnomalab » Mon Oct 12, 2026 10:39 pm
    Hi everyone,
    First of all, thank you so much for implementing the direct .tox file loading in MadMapper 6.2.0 Beta! It's an incredible feature and opens up amazing workflows. I've already tested some .tox files I created for VDMX and they run great.
    I've noticed that while some parameters map nicely into proper UI elements (like color pickers or toggles/buttons), others end up strictly as standard sliders. Is there any documentation or helper guide available on the correct naming conventions or TouchDesigner parameter types we should use so we can build .tox components with the right UI elements in mind consciously?
    Thanks again for your amazing work on this update!
    Best,
    Juanjo
    Captura de pantalla 2026-10-12 a las 22.36.30.png (1009.72 KiB) Viewed 1639 times
