worry !!!! *** inside us all FF plug-in question ?
  • timothy_boreale
    by timothy_boreale » Wed Jul 30, 2008 11:14 pm
    first at all , thanx for the hard work for freeframe ....
    i am using modul8 with mbp . os x 10.4.9
    when i add the plug in to my modul8 file ( plug-ins) , my modul8 can not open , it is said :
    thr app modul8 quit unexpectedly ...
    and when i remove the plug ins , i can open modul8 and no problem .....
    i will have a 4 days festival on this weekend . i really want to taste these plug ins . someone helps ???
    thanx !!!!!!!
  • timothy_boreale
    by timothy_boreale » Wed Jul 30, 2008 11:41 pm
    Date/Time: 2008-07-30 17:35:34.652 -0400
    OS Version: 10.4.11 (Build 8S2167)
    Report Version: 4
    Command: Modul8
    Path: /Applications/Modul8V256/Modul8.app/Contents/MacOS/Modul8
    Parent: WindowServer [73]
    Version: 2.5.6 (2.5.6)
    PID: 285
    Thread: 0
    Exception: EXC_BAD_ACCESS (0x0001)
    Codes: KERN_PROTECTION_FAILURE (0x0002) at 0x00000038
    Thread 0 Crashed:
    0 libSystem.B.dylib 0x900163c2 fread + 66
    1 AddictiveTV 0x006dd81a plugClass::InitialiseElementImageData(unsigned char) + 90
    2 AddictiveTV 0x006dda19 plugClass::plugClass[not-in-charge]() + 361
    3 AddictiveTV 0x006dda72 plugClass::CreateInstance(void**) + 34
    4 AddictiveTV 0x006dab94 plugMain + 260
    5 com.GarageCUBE.modul8_25 0x00109d9f G3PlayerUniversalFilterManager::readPluginsInDirectory(void*) + 441
    6 com.GarageCUBE.modul8_25 0x0010a145 G3PlayerUniversalFilterManager::init() + 157
    7 com.GarageCUBE.modul8_25 0x000590c8 -[G3PlayerClient applicationWillFinishLaunching:] + 244
    8 com.apple.Foundation 0x927f6237 _nsnote_callback + 230
    9 com.apple.CoreFoundation 0x908563ce __CFXNotificationPost + 345
    10 com.apple.CoreFoundation 0x9084db49 _CFXNotificationPostNotification + 600
    11 com.apple.Foundation 0x927ee7c8 -[NSNotificationCenter postNotificationName:object:userInfo:] + 121
    12 com.apple.Foundation 0x927f5769 -[NSNotificationCenter postNotificationName:object:] + 55
    13 com.apple.AppKit 0x9328bd02 -[NSApplication finishLaunching] + 355
    14 com.apple.AppKit 0x9328b8b2 -[NSApplication run] + 78
    15 com.apple.AppKit 0x9327f9c0 NSApplicationMain + 573
    16 com.GarageCUBE.modul8_25 0x00002ee2 _start + 216
    17 com.GarageCUBE.modul8_25 0x00002e09 start + 41
    Thread 0 crashed with X86 Thread State (32-bit):
    eax: 0xa0002010 ebx: 0x9001638e ecx: 0x90001778 edx: 0x00000000
    edi: 0x00000000 esi: 0x00000000 ebp: 0xbffff698 esp: 0xbffff660
    ss: 0x0000001f efl: 0x00010246 eip: 0x900163c2 cs: 0x00000017
    ds: 0x0000001f es: 0x0000001f fs: 0x00000000 gs: 0x00000037
    Binary Images Description:
    0x1000 - 0x30cfff com.GarageCUBE.modul8_25 2.5.6 /Applications/Modul8V256/Modul8.app/Contents/MacOS/Modul8
    0x62d000 - 0x62efff com.presenta.iGetterIMBundle 2.6.1 /Users/zongguangzhao/Library/InputManagers/iGetterIMBundle/iGetterIMBundle.bundle/Contents/MacOS/iGetterIMBundle
    0x6d9000 - 0x6ddfff AddictiveTV ??? (0.0.2d1) /Applications/Modul8V256/Plug-Ins/AddictiveTV.frf/AddictiveTV
    0x8e92c000 - 0x8e96afff com.apple.CoreMediaIOServicesPrivate 9.0 /System/Library/PrivateFrameworks/CoreMediaIOServicesPrivate.framework/Versions/A/CoreMediaIOServicesPrivate
    0x8efb9000 - 0x8efe3fff com.apple.CoreMediaPrivate 9.0 /System/Library/PrivateFrameworks/CoreMediaPrivate.framework/Versions/A/CoreMediaPrivate
    0x8fe00000 - 0x8fe4afff dyld 46.16 /usr/lib/dyld
    0x90000000 - 0x90171fff libSystem.B.dylib /usr/lib/libSystem.B.dylib
    0x901c1000 - 0x901c3fff libmathCommon.A.dylib /usr/lib/system/libmathCommon.A.dylib
    0x901c5000 - 0x90202fff com.apple.CoreText 1.1.3 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
    0x90229000 - 0x902fffff ATS /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
    0x90460000 - 0x90506fff com.apple.QTKit 7.5 (861) /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
    0x9080b000 - 0x908d3fff com.apple.CoreFoundation 6.4.10 (368.33) /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
    0x90911000 - 0x90911fff com.apple.CoreServices 10.4 (???) /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
    0x90913000 - 0x90a07fff libicucore.A.dylib /usr/lib/libicucore.A.dylib
    0x90a57000 - 0x90ad6fff libobjc.A.dylib /usr/lib/libobjc.A.dylib
    0x90aff000 - 0x90b63fff libstdc++.6.dylib /usr/lib/libstdc++.6.dylib
    0x90bd2000 - 0x90bd9fff libgcc_s.1.dylib /usr/lib/libgcc_s.1.dylib
    0x90bde000 - 0x90c51fff com.apple.framework.IOKit 1.4.8 (???) /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
    0x90c66000 - 0x90c78fff libauto.dylib /usr/lib/libauto.dylib
    0x90c7e000 - 0x90f24fff com.apple.CoreServices.CarbonCore 682.28 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
    0x90f67000 - 0x90fcffff com.apple.CoreServices.OSServices 4.1 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
    0x91008000 - 0x91047fff com.apple.CFNetwork 129.22 (129.23) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
    0x9105a000 - 0x9106afff com.apple.WebServices 1.1.3 (1.1.0) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/WebServicesCore.framework/Versions/A/WebServicesCore
    0x91075000 - 0x910f4fff com.apple.SearchKit 1.0.7 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
    0x9112e000 - 0x9114cfff com.apple.Metadata 10.4.4 (121.36) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
    0x91158000 - 0x91166fff libz.1.dylib /usr/lib/libz.1.dylib
    0x91169000 - 0x91308fff com.apple.security 4.5.2 (29774) /System/Library/Frameworks/Security.framework/Versions/A/Security
    0x91406000 - 0x9140efff com.apple.DiskArbitration 2.1.2 /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
    0x91415000 - 0x9141cfff libbsm.dylib /usr/lib/libbsm.dylib
    0x91420000 - 0x91446fff com.apple.SystemConfiguration 1.8.6 /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
    0x91458000 - 0x914cefff com.apple.audio.CoreAudio 3.0.5 /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
    0x9151f000 - 0x9151ffff com.apple.ApplicationServices 10.4 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
    0x91521000 - 0x9154cfff com.apple.AE 314 (313) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
    0x9155f000 - 0x91633fff com.apple.ColorSync 4.4.10 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
    0x9166e000 - 0x916ebfff com.apple.print.framework.PrintCore 4.6 (177.13) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
    0x91718000 - 0x917c1fff com.apple.QD 3.10.25 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
    0x917e7000 - 0x91832fff com.apple.HIServices 1.5.2 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
    0x91851000 - 0x91867fff com.apple.LangAnalysis 1.6.3 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
    0x91873000 - 0x9188dfff com.apple.FindByContent 1.5 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/FindByContent.framework/Versions/A/FindByContent
    0x91897000 - 0x918d4fff com.apple.LaunchServices 182 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
    0x918e8000 - 0x918f4fff com.apple.speech.synthesis.framework 3.5 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
    0x918fb000 - 0x9193bfff com.apple.ImageIO.framework 1.5.6 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
    0x9194e000 - 0x91a00fff libcrypto.0.9.7.dylib /usr/lib/libcrypto.0.9.7.dylib
    0x91a46000 - 0x91a5cfff libcups.2.dylib /usr/lib/libcups.2.dylib
    0x91a61000 - 0x91a7ffff libJPEG.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
    0x91a84000 - 0x91ae3fff libJP2.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
    0x91af5000 - 0x91af9fff libGIF.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
    0x91afb000 - 0x91b83fff libRaw.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRaw.dylib
    0x91b87000 - 0x91bc4fff libTIFF.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
    0x91bca000 - 0x91be4fff libPng.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
    0x91be9000 - 0x91bebfff libRadiance.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
    0x91bed000 - 0x91ccbfff libxml2.2.dylib /usr/lib/libxml2.2.dylib
    0x91ce8000 - 0x91ce8fff com.apple.Accelerate 1.3.1 (Accelerate 1.3.1) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
    0x91cea000 - 0x91d78fff com.apple.vImage 2.5 /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
    0x91d7f000 - 0x91d7ffff com.apple.Accelerate.vecLib 3.3.1 (vecLib 3.3.1) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
    0x91d81000 - 0x91ddafff libvMisc.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
    0x91de3000 - 0x91e07fff libvDSP.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
    0x91e0f000 - 0x92218fff libBLAS.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
    0x92252000 - 0x92606fff libLAPACK.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
    0x92633000 - 0x92720fff libiconv.2.dylib /usr/lib/libiconv.2.dylib
    0x92722000 - 0x927a0fff com.apple.DesktopServices 1.3.7 /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
    0x927e1000 - 0x92a11fff com.apple.Foundation 6.4.10 (567.37) /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
    0x92b2b000 - 0x92b42fff libGL.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
    0x92b4d000 - 0x92ba5fff libGLU.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
    0x92bb9000 - 0x92bb9fff com.apple.Carbon 10.4 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
    0x92bbb000 - 0x92bcbfff com.apple.ImageCapture 3.0.4 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
    0x92bd9000 - 0x92be1fff com.apple.speech.recognition.framework 3.6 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
    0x92be7000 - 0x92becfff com.apple.securityhi 2.0.1 (24742) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
    0x92bf2000 - 0x92c83fff com.apple.ink.framework 101.2.1 (71) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
    0x92c97000 - 0x92c9afff com.apple.help 1.0.3 (32.1) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
    0x92c9d000 - 0x92cbafff com.apple.openscripting 1.2.5 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
    0x92cca000 - 0x92cd0fff com.apple.print.framework.Print 5.1 (192.3) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
    0x92cd6000 - 0x92d39fff com.apple.htmlrendering 66.1 (1.1.3) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
    0x92d5d000 - 0x92d9efff com.apple.NavigationServices 3.4.4 (3.4.3) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
    0x92dc5000 - 0x92dd2fff com.apple.audio.SoundManager 3.9.1 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
    0x92dd9000 - 0x92ddefff com.apple.CommonPanels 1.2.3 (73) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
    0x92de3000 - 0x930d8fff com.apple.HIToolbox 1.4.10 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
    0x931de000 - 0x931e9fff com.apple.opengl 1.4.16 /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
    0x93279000 - 0x93279fff com.apple.Cocoa 6.4 (???) /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
    0x9327b000 - 0x93931fff com.apple.AppKit 6.4.10 (824.45) /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x93cb2000 - 0x93d2dfff com.apple.CoreData 91 (92.1) /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
    0x93d66000 - 0x93e1ffff com.apple.audio.toolbox.AudioToolbox 1.4.7 /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
    0x93e62000 - 0x93e62fff com.apple.audio.units.AudioUnit 1.4.2 /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
    0x93e64000 - 0x94025fff com.apple.QuartzCore 1.4.12 /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
    0x9406b000 - 0x940acfff libsqlite3.0.dylib /usr/lib/libsqlite3.0.dylib
    0x940b4000 - 0x940eefff libGLImage.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
    0x940f3000 - 0x94109fff com.apple.CoreVideo 1.4.2 /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
    0x9429a000 - 0x942a9fff libCGATS.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGATS.A.dylib
    0x942b0000 - 0x942bbfff libCSync.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
    0x94307000 - 0x94321fff libRIP.A.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
    0x94327000 - 0x9463ffff com.apple.QuickTime 7.5.0 (861) /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
    0x96ca3000 - 0x96cd9fff com.apple.audio.midi.CoreMIDI 1.5.1 (41) /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
    0x97717000 - 0x9771cfff com.apple.agl 2.5.9 (AGL-2.5.9) /System/Library/Frameworks/AGL.framework/Versions/A/AGL
    0x9842d000 - 0x984d0fff org.python.python 2.3.5 /System/Library/Frameworks/Python.framework/Versions/2.3/Python
    0x9fb14000 - 0x9ff69fff com.apple.CoreGraphics 1.258.77 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
    Model: MacBookPro1,1, BootROM MBP11.0055.B08, 2 processors, Intel Core Duo, 1.83 GHz, 1.5 GB
    Graphics: ATI Radeon X1600, ATY,RadeonX1600, PCIe, 128 MB
    Memory Module: BANK 0/DIMM0, 512 MB, DDR2 SDRAM, 667 MHz
    Memory Module: BANK 1/DIMM1, 1 GB, DDR2 SDRAM, 667 MHz
    AirPort: spairport_wireless_card_type_airport_extreme (0x168C, 0x86), 1.3.5
    Bluetooth: Version 1.9.5f4, 2 service, 1 devices, 1 incoming serial ports
    Network Service: , Ethernet, en0
    Serial ATA Device: ST98823AS, 74.53 GB
    Parallel ATA Device: MATSHITADVD-R UJ-857
    USB Device: Mobile Disk, USB2.0, Up to 480 Mb/sec, 500 mA
    USB Device: Built-in iSight, Micron, Up to 480 Mb/sec, 500 mA
    USB Device: LaCie Hard Drive USB, LaCie, Up to 480 Mb/sec, 500 mA
    USB Device: Apple Internal Keyboard / Trackpad, Apple Computer, Up to 12 Mb/sec, 500 mA
    USB Device: IR Receiver, Apple Computer, Inc., Up to 12 Mb/sec, 500 mA
    USB Device: Bluetooth USB Host Controller, Apple, Inc., Up to 12 Mb/sec, 500 mA
    deepvisual
    by deepvisual » Thu Jul 31, 2008 8:30 am
    bad install..
    http://vjforums.com/showthread.php?t=25324
    incidentally, these plug ins don't work on G4 macs.
    which is a shame.
