Midi Map NOT Working!
    tonyvought
    by tonyvought » Fri Aug 01, 2008 2:00 am
    I just upgraded my Modul8 to 2.5.6 and Midi Map no longer works. I cannot setup my UC-33e. I have the UC-33e connected to my Mac Pro via USB cord. Any suggestions? Please advise, this has completely shut me down.
    >tony vought
    tonyvought
    by tonyvought » Fri Aug 01, 2008 2:33 am
    Also, I don't believe that the UC-33e is broken because I have another controller connected as well and I cannot map it either.
    >tony vought
    david
    Re: Midi Map NOT Working!
    by david » Fri Aug 01, 2008 8:59 am
    Hello tonyvought,
    tonyvought wrote:Also, I don't believe that the UC-33e is broken because I have another controller connected as well and I cannot map it either.
    If you open the application Applications | Utilities | Audio MIDI Setup
    Does your UC-33e (USB Midi device) appears in it ?
    David.
    tonyvought
    by tonyvought » Mon Aug 04, 2008 12:33 am
    I opened the Audio MIDI Setup as you suggested and when I clicked on MIDI Devices the following error occurred... please advise. Thank you
    UNABLE TO LAUNCH MIDI SERVER
    Audio MIDI Setup was unable to launch the MIDI Server. This means that you will be unable to view or edit your MIDI configurations.
    Improperly written MIDI drivers can prevent the MIDI Server from launching successfully. If you have recently installed a new MIDI driver, try uninstalling it and then relaunching Audio MIDI Setup. If Audio MIDI Setup works correctly after that, then please contact the driver's manufacturer for further support.
    Click on this link to see screen grab of exact error message:
    http://img241.imageshack.us/img241/5492 ... rorig1.png
    >tony vought
    tonyvought
    by tonyvought » Mon Aug 04, 2008 1:31 am
    Forget it. I solved the problem. I recently installed Pro Tools on my machine and that installed a different MIDI driver. I uninstalled Pro Tools and that fixed it. That brings up a new question however, can Modul8 and Pro Tools exist on the same computer? If so, how do I go about making this marriage work?
    >tony vought
